Importing multiple ASCII files with same import wizard file (MXRoad .845)
Hi All,
Is it possible to import a serries of files (aprox. 250 +) .csv files at once, At the moment I use Import ASCII file (from file menu) and select import wizard file, apply the string name and run it.
Is there a option to select all the .csv files and apply the wizard file?
