Can multiple users open, write and save an openroads template library at the same time on a server?
It seems logical that this should work but I'm testing with another user and doesn't seem to work.
Parents Reply
  • It always uses the one in the DGN or IRD unless a user explicitly specifies to Synchronize from Library. If the ITL is not the same, you must use the element info or corridor objects tool to re-browse to the template (Ss4) or use the Template Drops dialog box in the Roadway Designer. The process is fairly painless either way - much more painless than having templates lost due to conflicting user saves.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
