Power GeoPAK SS4 templates causing crash
This is happening on Power GEOPAK v8.11.9.714.
When I first start a new corridor modeler file everything works fine, I can open/start a new template library, make and modify templates and adjust constraints. The issue arises after I close the library and try to get back into it or set a point control I get an Unhandled exception error. Not sure what is causing this and have tried everything else and different ways about going about it.
Anyone have some advice or a solution?
