[IR Ss2] InRoads Stationing dialog box has obsolete option?
I just noticed that the Stationing dialog box still refers to both Vertical Alignments and Super-elevation as something to be adjusted if the stationing of an alignment is made. As I understand it, Since the release of the Roadway Designer, Super-elevation was removed from alg files and relocated into the Roadway Designer Corridors.
So shouldn't the Stationing dialog box only offer to adjust Vertical Alignments?
However, this then begs a new question. How does one adjust super-elevation in the Roadway Designer after an alignments stationing is adjusted?
