Hello,I am working in Inroads Selectseries 4, and I want to create a simple terrain. I have no file to load. I just want a flat terrain without slopes, but in the tutorials there is always a file to import. I am recently working with the software for a small assignment at my University. Hopefully someone can help me with this.
Thank you in advance,Vincent JongmanUniversity of Twente
Draw a shape in 2D, any shape you want. Then find the Vertical Geometry tools > Profile By Constant Elevation command
This will assign the desired elevation to the shape
Then find the Terrain Model from Elements command to make a terrain model.
Bonus: Since you are making a flat terrain, maybe this is something like a building pad? If you need side slopes then use the following command and add the resltant elements to the terrain model as boundary elements.
Robert GarrettSenior Product EngineerBentley Systems Inc.
