<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>structure not found in open database</title><link>https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/116492/structure-not-found-in-open-database</link><description>Trying to add my structures and pipes to my existing profile but end up getting an error saying &amp;quot;structure not found in open database&amp;quot; Has anyone seen this before and if so how do I resolve it?
 Tpettis</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: structure not found in open database</title><link>https://communities.bentley.com/thread/358044?ContentTypeID=1</link><pubDate>Mon, 29 Feb 2016 13:33:29 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:03913743-3917-4614-a1d8-7c57a265d086</guid><dc:creator>Chris Key</dc:creator><description>So you have an existing profile created and you are trying to add your network structures to the profile when you receive this message?  When you are selecting the &amp;quot;To&amp;quot; and &amp;quot;From&amp;quot; structures are you using the selection button to graphically select the structures from the design file or are you trying to type the name of the structure into the field?  If typing the name manually make sure you are using the exact name so it can recognize the structure name from the database.  You may want to try an Edit/Review on the structure and see if you can copy the name and paste that into the To and From fields.&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
