Greetings,
Using Bentley Microstation V8i (select series 3) and Bentley InRoads Survey V8i,
The goal is to import survey data, and have the linework automatically appear via codes attached to points in the .CSV file. However, this is not happening correctly...
I am able to import the survey data no problem. Point name, elevation, etc. all appears legibly.
However, the linework associated with these points does not appear after the survey has been imported.
Please help with any information possible.
Thanks!
~Seth
Answer Verified By: Beebe Ray
