I'v a profile annotation problem.
In some cases MXdraw/Annotate profile does not works correctly.
Even centerline has geometry, and the mxtips file works in some other projects correctly, the result is very freak in few projects.
No chainage annotation, no horizontal geometry annotation, and even the interval is set up 20 m, all points are annotated at master and terrain section strings.
Any idea?
It looks, that there is no chainage information, but why?
Tibor
Hi Amita,
I have annotation problem while creating profile. It gives same RL for both existing and proposed ground.
I have tried all default tip file.
Thanks in advance!
Santosh Rai, EngTech MICE, ACP, BQT
Senior Designer - Highways
Hello Santosh,
When you are annotating the profile using the "Geometric Annotation", make sure the "Exiting Level" has the ground model selected and for "Proposed Level" make sure the "Design Model" is select. Please see below the image for better understanding.
