OpenRoads Modify Linear Feature Resets Terrain Edits
I've run into a problem when adding (start) to a point to create a linear feature for a road centerline.  When I create the new linear feature, all of my terrain model edits are reset.  I've added breaklines to the terrain and somehow they are just ignored and reset to the original survey import.
This first caption shows a bridge opening where I have created breaklines to represent the abutments.  This works like I want.
This caption shows how the terrain has been reset once I've created the linear feature in the center of the road.  You can see how the contour lines have changed
Please help
