I Can't copy my XIN preferences from an older project into my active XIN file. The apply button is greyed out! See image
Christiaan
Hello Christiaan, Please get a full access/rights of your system and then try to copy it. Regards, Purva Lakde
Christiaan,
What Purva mentioned is my first guess as well. Check the permissions on your current XIN. You need Read-Write permissions to use the Copy Preferences tool. If you have Read-Only it won't work. If your XIN is part of your Workspace and defined by a Config Variable, make sure you have full access to that XIN.
Answer Verified By: Christiaan Post
