Place a lateral command problem
When I try to use the command "place a lateral" it does not work out for me. I use an existing stormwater pipe, adding a new pipe and node with the same type as the existing pipe. The only product of the command is a point on the correct level, but no pipe or node is placed. What could be the problem?
Daniel Berglund
Parents Reply Children
