We have tried to export alignment (.alg) to i-model (.i.dgn) and after to i-model (.imodel) mobile for use on a iPad with OpenRoads Navigator but the data about the alignment is not on the included and there for we could not use the alignment based stationing.
I will hear how to export the alignment (.alg) and terrain model (.dtm) to i-model for use on the iPad with OpenRoads Navigator.
Is there a workflow for this process?
I import the .alg-file in to .dgn-file with PowerCivil SS3(08.11.09.497'9), when I publish to .i.dgn and then use NMP(03.00.01.18) to publish to .imodel.
Morten Skieller
edit: OpenRoads changed to OpenRoads Navigator
After I have used a lot of time on searching, I find this pdf * and from that the explanation is that the software is to old (OpenRoads/PowerCivil should be SS4 and NMP should be 5).
I have not access to OpenRoads/PowerCivil SS4 and therefor I cannot test if it works or not.
* http://communities.bentley.com/products/road___site_design/m/road_and_site_design_gallery/271541
I now have ss4 but there are still problems. I cannot see the “civil_imodel_include_icm” and think it could be because of the version of the software. It is not ss4 update(/Refresh) 1. How do I check if I have update 1?
What is the difference between SS4 and SS4 with update 1?
I am not sure if I use the examples workspace.
I have now tried to add the variable but the alignment is still not in the *.imodel at the iPad.
