MicroStation (Various): Installing Multiple Versions of MicroStation/InRoads/Map
We are often required to have multiple versions of Microstation and InRoads active on our workstations.  I am looking for a detailed workflow on proper installation procedures.  If a such a workflow does not exist, I would like to create one.  Can you assist?
In a big company, the users have lost most of the control of the installation process, and it is getting to a point where we need a written procedure to supply to the IT department, in an attempt to have a smooth installation.  For example, say a user has newer PowerInRoads version installed already, but needs to have Microstation XM and InRoads XM installed.  After requesting installation from IT, the IT rep tends to install just the requested software version, without regard to installation order by release date and the need to reinstall the existing software.  In the end, the software doesn't work correctly.
Can you help me with understanding:
  • when installation order matters and when it doesn't
  • how existing Microstation/InRoads/Map program versions are affected by installs of other versions
  • which versions can and cannot exist simultaneously on the same workstation
  • what about the workstation should be assessed before installation of anything
Are there other things to be considered?
Are there training topics that exist that I could review?
Thanks.
