In old InRoads, once you were happy with your survey data and wanted to make everything part of a drawing
you used "Write to graphics" and all the points, lines and symbols became permanent.
In OpenRoads SS3 I am trying to do the same thing without using old InRoads commands.
How is this done?
I have set a Variable "CIVIL_SURVEY_STRIP_OPTION" = 2
This seems to work, however it requires closing the drawing and re-opening to be prompted to "STRIP" the data to graphics.
I'm sure there must be a more direct method, without using old InRoads commands ???
Hi Andrew,
From Project Explorer, select your Field Book and Export to DGN Graphics.
Thanks!
Thanks Sanders,
But dunno why I hadn't "export to Dgn graphic" in ss3. (see below picture)
How does one control what is displayed as far an point names elevations notes etc.?
