OpenRoads Crashes when Window not Visible
Hi I'm running InRoads .845 and keep having this problem where if my superelevation editor or corridor objects window is hidden behind another window (I have two application windows running) and I go to the Window menu and try to select it it will Microstation/InRoads will just crash and the dialog box if I want to report this to Bentley shows up.  It sometimes seems related to having done a lot of edits and being in the file for a while but this last time I had only opened up my corridor and was reviewing things but hadn't made any changes.  Previously today this corridor crashed when editing superelevation due to the system "throwing an out of memory issues".  Sometimes if it is already open and I select the button I can also reproduce this crash.  So do I really have to close and reopen everytime I go to plan view and then back to editing my corridor or superelevation?
Neal
