InRoads Suite - Contours
Good morning, I am working in InRoads Suite.  I need to change 2' contour interval to 1' contours.  The problem is with saving the results. The 1' contours interval will not save.  What should I do?
  • Are you saving the change as a preference? Most InRoads commands with dialog boxes have Preferences. By default, if there is a preference named Default, it is the one that will initially load. Unless, in the Project Defaults dialog box, you can change the "default" preference to any one found in the XIN file loaded by default or by the active Project Defaults configuration.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
