OpenRoads V8i SS4 Maintenance Release 2 and import and export of .eav file
I just installed the new OpenRoads V8i SS4 Maintenance Release 2 and was going through the new things that have been added or fixed.  I ran into some trouble when I tried to export the values assigned for the End Area Volume tool.  When I try to export I get the error below:
I thought it might be a problem with the file extension (.eav) so I tried adding that to the end and got the same result:
We are using Projectwise and I noticed if I hit cancel on this window it will bring up the regular window and I can export the .eav file there to our local server but I can't save the .eav file to Projectwise.
