Hi
I have been trying to import either of the attached files. The “.txt” file is known as a “Geneo” file from 12D and is a replica of the “.12da” file.
I can import the text file as a surface but it doesn’t bring with it the string information of the model such as the centre lines and break lines and symbology.
All of this information is recorded in the 12.da file and can be seen if opened as a text file. I dont mind using MX, inRoads, Microstation Connect edition or PowerCivil if that helps to get the model from 12D --> PowerCivil.
Any help importing this sort of information would be appreciated.
File links ()
David Marx
