8.11.09.872 - A terrain model has a certain feature definition. I want to display triangles using thematic height but not change the feature definition. I set the template in element information to thematic height. (image 1) But the triangles are shown to match the view not thematic height. (Image 2)
Then, although I would rather not, I change the feature definition. Same result. Thematic height never displays unless I change the view to thematic height. Doing this of course shows everything in thematic height not just the triangles.
This appears to be caused by an error in the Civil Imperial workspace. The element template for thematic is set to Thematic Height - Civil, but no such thing is found in the list. (Image 3).
3rd image
Robert Garrett Senior Consultant
www.envisioncad.com
Hi Robert,
A defect has been filed for this issue: Defect 752932.
Hi.
I am now running OpenRail Designer 2020 release 2 and a slightly older version of OpenRoads Designer. This seems to still be an issue, at least in the training - metric workspace.
Thomas H. Stavik-KarlsenSenior Engineerhttp://www.Akersolutions.com
