Project Explorer Survey Tab
When I go to Settings- Project Explorer I only have two options for browsers (file and links). I don't understand why the survey tab option is not showing up.
The program was recently installed and I am a new user that may be missing something simple. I did spend a lot of time reading past posts with no luck resolving my issue.
I am using MicroStation V8i (SELECT Series 4) with Bentey GEOPAK Survey. Version 08.11.09.289
Thank you,
Kevin
Parents Reply Children
