I am working on our final model for the dtm, finished grade tin, and top of dirt tin in Geopak SS2 Roadway Designer. I recently had to create additional templates to aid in the top of dirt surface creation. In doing so, somehow now my top of surface tin is not triangulating correctly for the sidewalks in a few templates. I can’t seem to figure out what is causing this problem. This corridor now has over 20 templates and this is occurring in 7 of them. My recent changes to the corridor were primarily new templates to remove parametric constraints that made components go to zero (since the top of dirt alternate surface triangulated to those zero width components) and also merging points that were sitting on top of each other.
Anyone have any ideas what could be wrong?
Running GEOPAK V8i (Selectseries 2) 08.11.07.615, Microstation V8i
The problem is that the front face of sidewalk is triangulating to the bottom back of curb instead of the top back of curb in places. This is occurring inconsistently in 7 templates, which is why you see up and down or waviness in the green smooth modeling representation of the tin file from the original post. Hopefully the snip below clarifies the issue. The 3D components produced by corridor modeler do look correct. I have not tried to manually extract the surface from graphics. The best place to start looking is from station 2+28 to 4+25 on the SnowyRange corridor, template "SnowyRangeBarnRoofConc_NoRtSep". The sidewalk is triangulating correctly on the left hand side, but not on the right hand side. The template was recently edited to remove the sidewalk separation between the back of curb and front of sidewalk and merge the top back of curb point with the top front of sidewalk point. This was done so that a parametric constraint was not needed to force the sidewalk separation to zero feet wide, This was because the alternate surface needing to be created (for top of dirt) was incorrectly triangulating to that zero foot wide component. Snip below, other data will be uploaded through the secure file upload.
I've had the same problem in the past, though it no longer occurs with my current workflow. One piece of guidance I might have, though, is that from more recent work in the ITL file, I've noticed an attribute applied to points within the XML of the ITL file:
For example:
<Point name="inside31" featureName="" style="Znull" includeInSubgrade="false" subgradeName="" x="-0.766044443" y="0.357212390" isPartOfBackbone="true" superType="0" superTransitionType="0" superNonLinearLength="0.000000000" transitionX="0.000000000" transitionY="0.000000000" XByExternalControl="false" YByExternalControl="false" ControlledByParametric="0" isTopPoint="false">
I believe the key part here is:
<Point name="inside31" isTopPoint="false">
I haven't experimented with this before, but from what I can tell, this isTopPoint toggle appears nowhere in our template editor tools. And this toggle may be the issue at hand. You might want to open your ITL, locate some points that you know shouldn't be top points, especially ones that are picked up properly, and then locate some points that you know are causing trouble. See if you notice a pattern.
I don't know a particularly good XML editor, which would probably be of great help, but I use Notepad++ effectively. Just don't expect to get good use out of the Notepad that comes with Windows.
