When I create new file and try connect geocoordination services but its windowed 'No data found for the requested area' and I tried many different area on USA but not found data. Help me how I find the data?
This is how I process my geocoordination data server.
And any location its not finding data. Also follow that video.
Hello Andrew,
Thank you for your response.
I have tested the same on my system and I have reproduce this issue on my system, I could as well received the error of "No data found for the requested area".
But just for testing, I selected different coordinate system as shown in the below snapshot, I could able to see requested data in my view.
After that I created a new file and selected default coordinate system which you have selected in your view and hence it' s working fine now.
Please update us if it's resolved your issue.
Purva Lakde
Same problem if you try only check box of Terrain and Imagery. Otherwise if check roadway, building, hydrology its has some data. But I need only terrain and imagery data. Please find another way to find the data. Thanks very much your support.
