I have been using the new OpenRoads software with limited success due to consistent crashes. The most troublesome and persistent issue that I have experienced so far is when I attempt to look at the point controls in the corridor objects dialog. I get 2 microstoft .NET framework unhandled exception errors stating an out of memory issue. I have tested this on another coworkers machine with far more memory and she receives the same error. It is a major issue to not be able to modify when modeling a roadway corridor. Does anyone have any ideas how to fix this issue or ideas or what is causing it?
Geopak SS4 08.11.09.872
Microstation SS4 08.11.09.832
Ben
