OpenRoads Cross Section Reference Border/Elevation Numbers Help
I am using Microstation V8i v8.11.9.655 and I have a quick question about referencing a border into the generation of cross sections. I am able to get the border in there (including major and minor gridlines), I am just having trouble getting the elevation numbers to extend all the way to the top where they fit in the designated spot. The "Window Clearance" setting can be used, but it only properly affects the cross sections which go to a certain elevation (for example, if the window clearance is set to '30' to make the 'Station 97' (max elevation of 670) elevation numbers to fit properly, but then with the same window clearance set to '30', 'Station 100' (max elevation of 675) elevation numbers go 5 units higher than they are supposed to go.
I understand that I am able to put the elevation numbers into the reference border, but if I did this, the cross section elevations would not correlate with the border elevations properly.
Thank You.
