Why do ProjectWise paths in GEOPAK seem to omit the server and datasource from the path?
When setting a variable such as GPK_PROJMGR_PROJECTDIR in a Managed Workspace CSB as a ProjectWise Directory type, it resolves to the path with the server name and datasource in it, and GEOPAK isn't able to navigate the path. I end up having to use a string type and the syntax without the server name and datasource to get GEOPAK to recognize the path.
pw:\\[ServerName]:[Datasource]\Documents\[TopLevelFolder]\...
vs.
pw:\[TopLevelFolder]\...
Is there any way to have the paths resolve to the syntax that GEOPAK wants without having to hard code the path? Why the difference?
It appears that $(dev([ProjectWisePath])) resolves to pw:\\[ServerName]:[Datasource]\Documents\, so $(dir([ProjectWisePath])) provides exactly what we need to construct a version of the ProjectWise path that will satisfy GEOPAK. I was able to use pw:$(dir($(DMS_PROJECT(_DGNDIR)))) to construct a path to the root of the ProjectWise Project in the format that GEOPAK can use.
Answer Verified By: Mike Dillner
