I'm trying to create a report that gives me the Offset/Elevation of a template point at a set interval based off the stationing of the Main alignment.Example:I have a DITCH_CEN_LT point that defines the center of my ditch on the left side of my template. I want to create a report that will give me the Offset/Elevation of that point every 50' along the alignment used to create the corridor. IE: 1012+00, 1012+50, 1013+00, 1013+50, etc etc.Currently I tried using the Station Offset Report tool inside of Analysis & Reporting. I select my main Alignment, I select the 2D linework created by DITCH_CEN_LT, under options I have the interval set to 50 ... but when the report spits out the info it starts at 1038+11.83 ... the first station where DITCH_CEN_LT appears (There is a different template drop before that does not include DITCH_CEN_LT).EDIT: And as I look closer I'm realizing, it's not even spitting them out every 50 feet. It's 1038+11.83, 1038+61.50, 1039+07.96 ... I don't understand this report.Is there away to have it spit out a report that does it starting at the station of my choosing, like a nice round number?Thanks,Chris Williams
no you don't have to pick the feature from the 3d model if the plan element has an active profile whatever the method to get the profile was (profile, plan from 3D, ...). The CivilToolsStationOffsetExtended.xsl should report all the information.
I am trying to figure this issue out too. I want the elevation along a line created by the template. This report still gives me the elevation of the alignment I am using for stationing. Any other ideas?
