import alignment with a shift
The latest issue I am having with OpenRoads stems from the way it is importing alignment information from a gpk. I am trying to import an alignment that has a "shift" which is a traditional geopak cogo command which acts like a station equation, but intentionally does not recognize the distance between as stationed distance. Here is a snippet of the alignment as described in my original gpk:
Curve Data
Curve 1150
P.I. Station 728+29.72 N 161,641.3780 E 529,420.0954
Delta = 1° 36' 26.67" (LT)
Degree = 0° 30' 09.53"
Tangent = 159.9050
Length = 319.7891
Radius = 11,398.8330
External = 1.1215
Long Chord = 319.7786
Mid. Ord. = 1.1214
P.C. Station 726+69.81 N 161,481.4793 E 529,418.6631
P.T. Station 729+89.60 N 161,801.2539 E 529,417.0419
C.C. N 161,583.5827 E 518,020.2874
Back = N 0° 30' 47.61" E
Ahead = N 1° 05' 39.05" W
Chord Bear = N 0° 17' 25.72" W
Point 1155 N 161,801.2539 E 529,417.0419 Sta 729+89.60
----- Shift: 24.0000 (LT) at station 729+89.60
Point 1160 N 161,800.7956 E 529,393.0462 Sta 729+89.60
Curve Data
Curve 1165
P.I. Station 731+10.54 N 161,921.7089 E 529,390.7369
Delta = 1° 13' 05.78" (LT)
Degree = 0° 30' 13.34"
Tangent = 120.9353
Length = 241.8616
Radius = 11,374.8330
External = 0.6429
Long Chord = 241.8570
Mid. Ord. = 0.6428
P.C. Station 729+89.60 N 161,800.7956 E 529,393.0462
P.T. Station 732+31.46 N 162,042.5457 E 529,385.8573
Back = N 1° 05' 39.05" W
Ahead = N 2° 18' 44.84" W
Chord Bear = N 1° 42' 11.95" W
Course from PT 1165 to PC 1170 N 2° 18' 44.84" W Dist 784.5136
Here is a snippet of what is described after the "import geometry" tool is used in OpenRoads:
Curve Data
Curve 35WSB_24
Tangent = 159.9050
Length = 319.7891
External = 1.1215
Mid. Ord. = 1.1214
Course from PT 35WSB_24 to PC 35WSB_27 S 88° 54' 20.95" W Dist 24.0000
Curve Data
Curve 35WSB_27
P.I. Station 731+34.54 N 161,921.7089 E 529,390.7369
Tangent = 120.9353
Length = 241.8616
External = 0.6429
Mid. Ord. = 0.6428
P.C. Station 730+13.60 N 161,800.7956 E 529,393.0462
P.T. Station 732+55.46 N 162,042.5457 E 529,385.8573
Course from PT 35WSB_27 to PC 35WSB_30 N 2° 18' 44.84" W Dist 784.5136
Notice how the second chain description snippet is not the same as the first set of information. How is it that the import geometry tool in OpenRoads cannot make sense of supposedly supported legacy format alignment information? Was this not tested by Bentley prior to release? This is the latest of many very disappointing and in my opinion, completely unreasonable errors/omissions/bugs to be present in a software that is classified as a stable fully functional release. I have beta tested software that is more functional and stable than this piece of software.
