Import/Export Parametric Constraints
I like this new addition to the parametric constraints tool. But I noticed something strange.
Our users are instructed to use the precision settings of 0.1234567 for Northing, Easting, elevation, slope and linear while working with templates and roadways to avoid roundoff creep.
If you export a set of parametric constraints, it rounds them down on decimal place which is not critical, but it is not what I would expect from InRoads. At the very least, it should export the maximum stored precision or values based upon the users precision setting.
Parents Reply Children
