I am trying to setup a survey field to finish in Power InRoads. I have set many up in Civil 3D, but I am having trouble figuring out the web of files needed in order to get the correct symbols and line work in. I typically import just a text file/.csv. Point Northing Easting Elevation and Code with the basic commands of B=Begin, E=End, PC= Point of Curvature, PT= Point of Tangent, and CLS=Close figure. I have started altering the .xin file for the codes, but I am having trouble with getting symbols in and getting the linework on the correct level. I have found and altered the "LinkCodes". Also, on import anything with a "B" at the end gets removed. Example "CB" turns to "C". I assume it has to do with the Begin command. I have yet to find anything that explains the process and the files require to make this happen.
