Backface culling in 3D viewport
I've been trying to deal with z-fighting in the surfaces in my 3D view.  I've managed to address some of it by ensuring terrrain surfaces weren't drawing triangles and by enabling front and back clipping (which seemed to have a mixed effect).  But in the end, there's still some mystery polys that are being drawn that I can't seem to eliminate.
Any thoughts?
  • Taking the 'slab' as an example, it looks like there is a rectangular shape as well as the 3D slab. The top face of the slab is in the same place as the shape, So I would simply turn off the level that the shape is on. Front and back clipping would not come into play with this - as those clipping planes are to do with the complete 3D model.
    Answer Verified By: Joel Graff
  • Edit:  I should note I've also mixed up my terms a bit - I have meant to achieve better Z-culling -(removing faces that are occluded by other faces in the scene) rather than backface culling, which is removing faces whose normals face away from the camera...
    Mark,
    You're right that camera clipping shouldn't have anything to do with this problem, but it did help to "calm" the effect a little bit. For example, the darker gray slab with the yellow edges is an asphalt road with a subbase (the yellow). Before I turned on camera clipping, the subbbase faces fought with the asphalt faces, although there's substantial (several inches) of difference in their heights. So, when I saw how camera clipping cleaned up that issue, I presumed Z-culling was also taking place, and not just a simple cutting of the volume between a front and rear plane...
    Anyway, I suspect it's probably because we're running low-spec video cards, so obviously anything that reduces the total visible volume would probably help issues like that.
    In the end, shutting off the shape's levels fixed the problem. Thanks for the tip.
