I need help with adding pipes to a profile.
Heya,
I'm trying to create a profile showing a pipeline versus terrain. Both of them are lines. I also have a fake surface at elevation '0', just to get things started. I've managed to create a profile over my surface, and I've added the terrain-line. I'm not sure how I did that. But now I'm trying to add my pipelines, and it won't work. I try "Evaluation" --> "Profile" --> "Alignments to profile", and then I select the first pipeline alignment, using the Microstation View, to add the first pipeline alignment I wish to add. I chose a different color so it stands out, and the message bar says "Successful Completion", but no pipelines appear in my profile.
Here is a picture of the alignments/pipes I need to get into the profile:
I need to get all the alignments call 'Gas' into the the profile. I can't really make them into a single line because some of the stretches are measured directly while some are directional boring, so the profile needs to destinguish between the two.
Most of what I've tried to do so far is trial an error, so don't hesitate to ask clarifying questions. I have made sure my elevation range is set properly. I've set my profile range from -10 to +30 and the pipe/terrain range is -1 to +20, so it should show up.
Best regards,
Jacob
