Is there a way when cutting cross sections in SS4 to cut to a model that you have already cut cross sections into instead of creating a new model?
Answer Verified By: Wesley Nyberg
I second this. This would be incredibly helpful. I understand that some might say this could be further improved by adjusting elements that are hand-drawn, but (from my own point of view) even if it does nothing but re-cut cross sections to match the cells already established, that could save quite a bit of time associated with re-laying all the cross section sheets and copying in elements from another cross section file, for example.
I feel that there should be an option to add new cross section cells (and the cross sections that belong to them) to an existing cross section model so we can add sections at driveways or drainage structures in case we failed to do that earlier. I feel that we should be able to locate them via datapoint or some other way to provide coordinates, so that they don't interfere with other cross sections that are already positioned.
