I have an MX Drainage model that includes a section with 2 pipes between the same nodes (MX Drainage allows up to 3). When I import it into SUDA it comes in without error but only with 1 pipe instead of 2. Is this a limitation of SUDA? If so, is there a workaround I could use to allow me to put more than 1 pipe between the nodes?
Answer Verified By: Grant Stewart
