Hopefully someone can help me, my client is looking for a GENIO format for text which includes the easting, northing, elevation, angle of the text, (in degrees from the vertical) and the text size (in cm). The supplied text is in CAD format.
The client gives 2 examples, see below....
DELETE,TEXT
CREATE,TEXT
EDIT,TEXT
002,3=*002,5=349114.79247,6=310733.69794,7=90.,9=0.15
001,This is text created in major option EDIT
002,3=*003,5=349114.86917,6=310732.75494,7=90.,9=0.15
001,This is more text created in EDIT
999
The value in field 3 is the string label, which for text strings always starts with *, field 5 and 6 are for the easting and northing of the start of the string.
The value in field 7 is the angle of the text, in degrees from the vertical, and the text size (in cm) is in field 9.
Any help would be much appreciated.
Paul
Hi Simon,
Attached is a dgn file containing the text. Hopefully this helps.
Hatching.dxf
