I have a entrance pipe that I have modeled with SUDA and it is an ellipse shape in the feature definition. For some reason when I cut a cross section it doesn't show up but it does in the temporary cross section view. If I change that pipe feature to a circular shape with a different feature definition it shows up when I cut cross sections. Has anyone else had trouble with ellipse shape showing up in the cross section? I have other pipes along this stretch that are circular or a box and show up fine in the cross section so it being an ellipse was the only thing different that I could figure out might be the reason (wondering if this is just a bug).
Answer Verified By: Wesley Nyberg
We have a Designer here at IDOT that is having this same issue now. I see this post was over 2 years ago and a defect was filed. Has there been a resolution, a setting that might need changed or is it still being worked on?
This was fixed in the latest release of the SS4 products. So V08.11.09.904 for Power GEOPAK/InRoads or V08.11.09.903 for InRoads/GEOPAK running layered on MicroStation.
Hi - I'm running Power InRoads V8i (SS4) Version 08.11.09.904 and this issue is happening for me. To clarify, I am able to see elliptical pipes in the "CrossSection View", but if I use the "Create Cross Sections" tool (which is what I want to do), the elliptical pipes do not show up in the created sections.
Can anyone advise on how to fix this issue?
