I'm trying to run the End Area Volume tool and need to set surface type for components. However, the window/column cannot be resized so that I can read the object column. Why would someone create a window like this? #SMH
I don't know what version you are on, but it resizes on InRoads SS2.
This is a problem in PowerGEOPAK SS4 08.11.09.878. Has anyone found a solution?
Thanks!
Matt SextonCADD Applications Support CoordinatorFlorida Department of TransportationEngineering/CADD Systems Office850-414-4840matt.sexton@dot.state.fl.us
