When working with corridors in earlier versions, I sometimes found it necessary to use the Horizontal and Vertical Element tools to break alignments at a specific location and other times to change the starting element of a closed alignment.
What would be the workflow to accomplish this in Open Roads?
I have an ALG of the alignments that were manually exported to native. Can I edit the ALG alignments and re-import them back into the DGN file or will that be blocked?
To change the start element for civil geometry, you should drop the feature using the MicroStation Drop Element tool. You would then use the OpenRoads Complex By Elements tool to recomplex the feature. You would simply pick your new starting element first. This would be identical to the workflow to reverse the direction.
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/23145.change-direction-of-horizontal-geometry
To break the feature, you would just use the MicroStation Break Element tool.
