Can any body help through this, can i know how to import autocad drawing file to open roads .SH-96_Kolar .dwg
Frank
8816.SH-96_Kolar .dwgCan you please work through this dwg file and send the vedio.
Hello Chetan, The link which I mentioned earlier same process has been followed for this .dwg file.Please refer the below link for your reference. bentley.sharefile.com/d-s507ee7a1b864a8aa Regards, Purva Lakde
