COGO and .tin file
COGO can not read a .tin file.  I tried to grab an elevation from plan view labeler and only reads "Not available".  I tried to generate an existing profile using the same .tin file but I get an error message stating "unable to store profile".  Basically COGO can not read the .tin.  I'm having the same  issue with other projects and .tin files.
