Hi all
Am getting this error.if i click road design options carriageway design is not active.can any one tell why this error.
Best Regards,
Kugan (Account Manager & Technical Adviser on MX and ORD)
Answer Verified By: sunilkumar DS
Hai this Is zappy,
i have a doubt in mx road, while redesigning horizontal alignment the vertical profile will be changed then its levels of FRL is changed how to recorrect those FRL can u guide me
Okie if you want retain same existing vertical Levels you have to run previous vitemp values to new alignment .
Step1:Before you make change in alignment take backup file for vertical tip file(Mxdata-vitemp)
Step2:Change the Horizontal alignment
Step3:Update stat and end chainages in previous vitemp
step4:Run the input file vertical now.
it wil work
Note:however if you have maintained any frl at particulat chainages it wont remain same.
