Cutting Cross Sections in SS4
I'm trying to cut cross sections from a horizontal alignment (intersecting street) that is 100' long with only two points. I need a cross section at the beginning, middle and end of the alignment but for some reason using the Create Cross Sections Tool will not cut them for me. Not sure if it's the short length of my alignment as there's other alignments that are a bit longer and will actually cut cross sections for me with only two points as well. Is there a minimum length that alignments need to be in order to cut cross sections? If yes, what's the needed length? Below is the version of Microstation and Geopak that I'm using. Any help or suggestions will be greatly appreciated.
Microstation: 08.11.09.714
Geopak: 08.11.09.845
