I am unable to edit my feature definitions library.
Is there some sort of setting I am missing? I want to modify and create a number of feature definitions for use in SUDA but when in Project Explorer, right clicking literally does nothing except on existing Feature Definitions (which only offers to view the properties). I have full write access to the file but none of the Feature Definition creating/editing functionality is available to me.
See below: All of the Feature Definitions that are live in this .dgnlib file are colored dark-gray (as opposed to the referenced libraries which are a light-gray). They are actively in the file but if I want to rename, reorganize, create, or basically anything, I cannot. Every tutorial and video on the Feature Definition library assumes this supposedly easy task is available to all. I feel like I am missing something important yet very easy!
This video is not done in openroads designer Where can I change the feature definition and create one? Is this in the dgn library? If so how to upload it and change the default feature definitions?
No dgns exist under my imperial standard folders except the read me files Thank you.
