Create New Linear Feature with Context Menu
Anyone know the command for Create new linear feature so I may add it to my Context menu?  I use this command constantly and would like to invoke the command using my pop up menu (context menu) when i hold the right mouse button.
Where can i find the key-in for the survey commands?
  • I don't believe there is a key-in for this particular option.  When you are creating a new linear feature, it is specific to a Field Book you are adding a linear feature into so you have to right-click and add a new Linear Feature through the Survey Field Book in the Project Explorer.  You can have multiple Field Books loaded and there is no 'active' fieldbook.  So I don't believe there is a way to add a New linear feature other than through right-clicking on the ALL Linear Features tab under the Field Book and adding the feature.
    http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/21893.video-create-new-linear-feature-by-adding-points
    I generally use the search function in the key-in to find specific available values.  I started by typing in survey... and it began to fill in the options when I selected the search function.  Then I can drill down and see each available option for the commands through they key-in.
    For more information about the Road and Site design tools, visit the Road and Site design WIKI at: http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
    Answer Verified By: EL_C_
Reply
