Function "Annotate drawings or Pages" doesn't work??
Welcome everyone. I want to us function Annotate Drawings or Pages. When I click on this function I don' t have nothing. This function doesn't work in my MXRoad. What I have to do to fix this problem??
  • Can I ask how you solved this issue specifically because I am having the same problem?
  • This is an older thread, So I imagine they won't be coming back to see your question.
    From reading the thread above, it would appear that the first gentleman's issue was solved by a "windows format" and a fresh installation of MX.  I don't know if the actual solution needs to be so extreme...but I don't run MX, so I'll be of little help.
    I'd suggest starting your own thread, and describing your issue in as much detail as you possibly can. Please be sure to include which version of the software you are running (by version number, i.e. 08.11.xx.xx). Different versions may or may not have bugs or workarounds specific to that release.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
Reply
    MaryB
