Power InRoads V08.11.09.878_SS4
Once I create a cross sections set in Microstation model in openRoads, is there a way to update cross sections such as display crossing or project features?
James
Hi James,
Yes, you can update the cross sections for features and crossing features. Once you have the cross sections created, select the option "Annotate Cross Section" in the "Corridor Modelling" task (just besides 'Create Cross Section' option). Here you will find the "Features" category, you can select the "Crossing features" you want to display.
Hi Amita,
Thank you once again for your help.
Well, without text annotations such as feature name, station, and elevation, I meant to turn on & off cross marks that represent crossing or project features. In SS2, I refer to updating cross sections command; refresh, turn on & turn off.
Beside that, using annotation cross section tool that you mentioned, once I displayed text annotations for crossing or project features, how to turn it off? When I checked design surface for instance and select none in Feature > Annotate section and click apply button, text annotations remain same on Microstation view.
I could use undo to go last, but I just want to double check see if there is another command to do so. Thanks~
Frank
Sounds good Frank. I'm looking forward to test Bentley the Connect version.
Keep in touch.
MaryB
