LDD to PCi
First of all, THANK YOU!!!
However, just ran it and when importing the XML through Survey/geometry/Import it ran for a few seconds and then Windows shut down  PCi with the infamous "Send Error Report message?"  Since I am so knew at this, is this the proper place to import, the impression I got was that this is for Geometry only (from the menu heading)?
Gary E.
Parents Reply
  • We could use some clarification on this new feature. The import from LDD tool generates a single XML file that seems to contain points, alignments and surface models from the LDD project. Power Civil does not seem to be able to utilize this XML file so there must be some new tools to import from this new XML file.
    Neil
    Neil Wilson (aka Neilw)
    Power Civil v8i 08.11.07.245
    AutoCAD Civil 3D 2018
