Is it possible to create Cross sections from the Corridor Modeling dialog along an alignment with pointcloud data?
Thanks in advance.
Regards, Christiaan
Any news on this one?
Did you try using the Microstation tools to create your sections?
Yes but time consuming and not a solution if you have a 10 km track :)
did you try converting your pointcloud to a STM or 3SM and then cutting your section?
Tried but after 2 days and 45 min the Context Capture model wasn't created
Hi Christiaan,
The Cross Sections are almost the same as the detailing symbols or Clip Volumes in MicroStation. For displaying point clouds here, the same trick can be used.
Enable Forward in the Reference Presentation in the Cross Section Model. After that look in the information of the Named Boundaries and increase Forward depth in the Clip Properties.
Regards Louis
Answer Verified By: Christiaan Post
Hi Louis,
Thanks, this is a good solution and the most important thing it's working:)
//Christiaan
