Anyone recall if the geopak plan/profile sheet composition tool was designed to work with multiple MicroStation models?
This tool works fine with placing sheet clips shapes in multiple models with Geopak ss2. But, using Geopak ss4 (openroads), I have to click through a number of errors "Missing Application Data, Input Missing Data" before I can get the clip shapes placed into my active model.
No, I am only in a default model, I have it set to use the design file and not a motif.
what version of geopak are you running?
ok. can you describe your problem? what is it doing? not doing? have you tried cleaning your resource files?
make sure there are no hanging geopak.exe processes running in windows (task manager)
Delete everything under the 8.11 folder
C:\Users\ yourusername \AppData\Local\Bentley\MicroStation\8.11
I am running v8i SS4, but I tried opening with SS2 and had the same problem.
As soon as I open the plan/profile sheet composition tool, a message appears that reads: "Missing Application Data. Input missing data?". If I click yes, it wants to know the PSL file, what type of sheet, the GPK, the chain name and the motif file. I have never used motif files because I always have my view attributes set to use current design file. I have never seen this error message before and use this tool all the time. If I click no and continue to work, the error pops up several times and when I try to clip my sheets, it says, "Unable to process sheets. Missing Motif file".
There was a geopak.exe process running this morning, and I ended it. I also deleted everything in the 8.11 folder. Then I started from scratch creating a brand new profile and PRJ and new DGN and I still receive this message. Yesterday, I tried filling out all the information it wanted. I just picked the DGN I was in as the motif file and the sheets processed, but the only thing in the DGN was the sheet. Then I changed my view attributes to use the motif and it never let me select a motif from there, and it still didn't attach my profile to the sheet or anything at all as a reference. Then I couldn't get the error message to pop back up again to remove the motif file or change it or anything. I tried deleting my resource files yesterday as well, but I'm not sure I got everything because I don't know where they all get stored.
Thanks.
Ok. you need to make sure that your resource files are gone. Check in your working directory and make sure you have no .rsc files there. Also, see this post, in case they are being redirected
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/15923/geopak-resource-files-how-to-remove-them-and-why
I just did this and still receive the error-however it did process my sheets correctly finally.
