Cross Section Component Display Problems
Hi, Using InRoads 8.08.00.46 and trying to generate cross sections.  The problem is that some of the components are not displaying properly.  For example, I have my Left lane component sloping the opposite direction in the cross sections or 2 curbs at different elevations appearing or 2 lane components stacked on top of each other, etc.  However it is not doing this in Roadway Designer and furthermore the same templates are used elsewhere in the corridor and they work there.  The only unusual thing maybe is that I am using point controls to vary the roadway width by following alignments.  But if it works in Roadway designer and elsewhere in the corridor why would it not work elsewhere.
