I am creating intersections. I have a mainline corridor, and have enabled end condition exceptions thru the intersection area to use backbones only. I then have a corridor along each corner radii. I am targeting the edge of road and the cross road centerline, and everything looks great when looking at the "features and components". I looked at the contours and see that there is an issue where the three corridors come together. I looked at the triangles made from the 3 corridors, and see that the triangles seem to not be targeting the center of the intersection as expected. We think it may be an issue with maximum triangle length, but cannot find a setting. It may be something else. Any thoughts on how to bring the intersection together would be greatly appreciated.
BTW, I have tried creating the surfaces separately and combined and both are an issue. I was surprised that just an individual quadrant has the triangle issue.
Joe Lukovits
User Since TDP in the 80's,
Vax based Unix Workstations - Interpro32,
from the Intergraph Corp.
ok. now my looks "perfect", but the cross sections don't plot correctly. The side street linework doesn't plot. Am I missing something? Is there a workaround for this?
Answer Verified By: Dawn Michel
The orange us existing ground. The section is cut along mainline. Mainline structure is shown, but the side street structure is not showing up correctly. It is just showing as text (named the radii corridor name and station)
I have point controls set for the top surface. the lower surfaces are set from the top, so I don't think that is an issue. I'm curious as to how the surface looks good, but the section isn't cut as expected. Someone else in the office said they have trouble with sections cut from one centerline that were created from another centerline. I thought the surfaces were more independent than that.
The red line is a snapshot of where the section was cut. It is skewed, but the perpendicular ones have the same issue.
The 3d view looks good (I have the aggregate turned off below, but it looks good when I rotate the model)
Thanks for your help.
